adding a backdrop from the edit menu
rbowrbow Posts: 10
In DAZ Studio 4.6, I enjoyed adding a background scene by going to Edit...Backdrop. How can I do this in DS 4.7?
  • Richard HaseltineRichard Haseltine Posts: 111,972
    That function has been moved to a new pane, go to Window>Panes(Tabs)>Environment. If you use backdrops a lot, dock the pane so that it's available with a single click.
  • fixmypcmikefixmypcmike Posts: 19,738
    It is now located in Window > Panes > Environment
  • GintonikGintonik Posts: 1
    This is great, however there is no indication of how to actually add an image background. Also not in the user guide.
    edited January 2015
    Set the Active type to backdrop and the rest of the controls will appear. There is a fuller entry in the FAQ, linked below.
  • Steven-VSteven-V Posts: 727
    Man oh man, this drove me nuts the other day. I could not figure out where the option had gone!
  • airboss1airboss1 Posts: 68
    You can also map your photo onto a flat plane then the camera dof can be used
    Paul
