How to fix hair
我做了一个简单的头发,在出现的其他角色中有折痕。我该如何解决这个问题?
1394 x 856 - 680K
1394 x 819 - 264K
How did you make the hair? Was it made for the base figure? Have you rigged the hair?
1. I imported the hair OBJ and used DAZ's Transfer Utility function.The hair then has the skeleton of G8FM and then I save the hair.
2. Save As >>>Support Asset >>>Figure/Prop Assets
3. When using the saved hair on other characters, there are questions.
Applying other characters to G8 figure will auto-generate the character fit morph on the hair. This is sometimes ok but most times not good. You can repair or modify that auto generated morph:
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/modeling/tutorials/repair_distorted_morphs/start
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/modeling/tutorials/modifying_morphs/start
And for advanced use you can apply rigidity so character morphs do not affect most parts of the hair in future:
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/rigging/tutorials/rigidity/start
It is a lot of work to fit many characters
Really helpful.
