Flipmode "Easy Environments" iRay
JoltrastJoltrast Posts: 208
edited June 2021 in The Commons
I'd like to use Flipmode's Easy Enviroment sets with iRay, but even if I convert everything to iRay it still renders black. Any idea what I need to remove from the scene please? Thanks.
198 x 202 - 6K
Post edited by Joltrast on
  • GordigGordig Posts: 10,844
    Does it have a skydome?
  • JoltrastJoltrast Posts: 208
    It has a SkyBox (SB). Can I use the materials from the box without using the box?
    Depends on how the materials are set up, I suppose, but presently the skybox is probably blocking all your light. Try hiding it and render again.
    Yeah, I figured. I'll have to see if I can use the textures because it looks kinda flat without them. Thanks.
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited June 2021
    With some old style skydomes, sometimes I create an opacity map where the back end is 100% transparent.
    The goal is to preserve the dome in the direction of your camera, but cut out the back end of the dome (out of the camera's eye) to let in the HDRI and/or Distant Light.
    Not sure how that one is set up & whether or not you can create an opacity map for it, however.
    (EDIT: Ugh, I mean transparent, not translucent. Insufficient coffee at the time.)
    Post edited by The Blurst of Times on
    The Blurst of Times said:
    With some old style skydomes, sometimes I create an opacity map where the back end is 100% translucent.
    Ooh, that sounds like a novel solution. It might even work if I do that to the bottom pane. I'm going to experiment. Thank you for the suggestion!
    Leana said:
    Check this: http://flipmode3d.com/converting-3delight-skies-to-iray/
    I was just coming here to post that as the solution I found! Thank you!
  • FlipmodeFlipmode Posts: 951
    Only noticed this thread just now...
    Glad you guys found the "tutorial" link, I hope it helped. :)
