Making stage lighting not affect a texture?
Sand3Sand3 Posts: 101
So I have a photographic background stuck on a plane primitive and I want the photo to be completely unaffected by all the light on the stage and just render true to the original photograph, what settings do I use in the materials window to make an object not get any shading? I've done it before, and I thought it was turning off either ambient or specular, but I'm trying to do it and can't seem to make it work now.
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    edited December 2014
    The main channel affected by light sources would be the diffuse channel, that said you could always place your image in post. Set it up to render, then hide the background image and then replace it in post. Or you can set the image in the Environment pane as the background which I believe isn't influenced by lighting either. Of course it would depend on how you have set things up whats easier.
    Post edited by Design Anvil - Razor42 on
  • millighostmillighost Posts: 261
    something like this should do:
    432 x 455 - 86K
  • fixmypcmikefixmypcmike Posts: 19,738
    You need to put the image in the ambient channel.
  • Richard HaseltineRichard Haseltine Posts: 111,958
    In most cases it's enough to have the image in Ambient or Diffuse, not both, as they are multiplied together. uber Area Light is an exception to this.
  • Sand3Sand3 Posts: 101
    Thank you, that's exactly what I was looking for!
