Noob Question
AntausAntaus Posts: 41
I'm using the Michael 4 for Genesis 2 program to try to apply a skin texture, the only problem I have is that the texture won't apply. I click on the texture to apply, the loading bar appears, but then nothing happens. Have I perhaps installed something wrong? I know the textures work because I've applied the face skin manually using the surfaces tab. The UV load works because it maxes the default G2M texture looked all screwed up.
Now for something else, this is the real noob question. The skin I'm using has options for different eyebrow colors... how do I apply eyebrows manually in the surfaces tab?
  • fixmypcmikefixmypcmike Posts: 19,742
    The material presets need to be converted to .duf to load on G2M. Load M4 (or Genesis 1 if you don't have M4), apply the materials, and save as a material preset, then it can be applied to G2M.
