crashes when applying pose
daz studio 4.15 crashes all the time and every time i add a pose it crashes not sur why ?
this is from the log file>>>>>>CloudFIle::lookupFromDb: Unable to connect to the database
2021-06-19 14:41:53.144 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
Did you ever get this resolved https://www.daz3d.com/forums/discussion/452071/daz-studio-cashes-when-logging-in#latest ? Are you now working online or off?
i have tried everything its always crashing and now every time a add pose daz just closes
this is what the log file says after i try to login ..........2021-06-19 15:08:39.008 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentFilterPathsToCloudInstalledContent: Unable to connect to the database
2021-06-19 15:08:39.067 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetByRelativePath: Unable to connect to the database, can not quote
And are you working with DS online?
no it wont let me login
what i get when i try to login
In that case you should get a similar dialogue on starting DS - do you?
yes but its to long to post here here is the log file txt
That's a pretty limited system - 8GB RAM, Celeron processor, and only an Intel GPU - I would suspect there are a lot of places for things to fail. It's also failing to Connect to PostgreSQL, used by the content management system - is that installed? If so what security software are you using?
