G8f & G8.1F (SOLVED)
PlatnumkPlatnumk Posts: 682
It seems I have come across a strange problem,  If I load any G8F character into a empty scene then add any G8.1F Character into the same scene they both occupy the same space & if you move one character the other moves as well.
Edit : Looks like you can't have 2 G8F Charcaters in the same scene either as the both load on top of each other & if you move one the other moves.
Post edited by Platnumk on
  • felisfelis Posts: 6,502
    Something sounds off.
    You should be able to load X G8 characters without interacting.
    When you load the 2nd, you haven't still the first selected in the scene tab?
  • PlatnumkPlatnumk Posts: 682
    Nope,  When I loaded the 2nd I had nothing selected in the scene.
    I have tried resetting the database & I have tried uninstalling the g8 starter essentials and re-installing them but the problem still happens.
    I can provide a link to a video showing the problem in action if required
    A screenshot or something would be good - it doesn't make sense to me.
    Link to video Geneis 8 Problem
    When you have both enabled you can see there are clipping in the head, meaning both are there.
    I think there are just about the same size.
    You can try colour one red, then I think you can see the clipping much more clear.
    I managed to solve the issue - Looks like I was moving the perspective view camera instead of the figure (Bangs bead against the wall)
