4.7 Toon Render Setting
SassanikSassanik Posts: 340
Okay, there used to be a way to change the render setting from "default" to "cartoon"
Now with the new render settings I am not seeing where this setting has been moved to.
Suggestions? Ideas?
Thanks!
Amy
  • Richard HaseltineRichard Haseltine Posts: 112,021
    From the Render Settings pane option menu (the lined button in the top corner, or right-click the tab) enable the display of hidden properties. Remember that the cartoon mode affects only the DAZ Default Shader.
  • SassanikSassanik Posts: 340
    Thank you! I knew it had to be in there somewhere!
    Amy
  • ChromaDrakeChromaDrake Posts: 288
    edited January 2015
    Finally, I just wasted a bunch of time trying to find that thing too. It was particularly weird because that option showed up when I did NOT have the Hidden Properties checked. It was there and I switch it then it disappeared and I spent all the time trying to find it again before I looked up this thread. I know the Hidden box wasn't checked because I just checked it and the Cartoon option re-appeared.
    Post edited by ChromaDrake on
  • Thank you. I have been tearing my hair out knowing I'd seen it in there somewhere!
