Hide Polygons when loading a Figure
Hey Community,
I know i have found the solution for my problem some month, but I just can`t remember it anymore... and I can`t find the post where the solution was described...
My Problem: I want to hide Polygons on Genesis 2 when I load a Figure (e.g. a glove) and fit it to Genesis. The Polygons to be hidden do not match the bodyparts or surfaces, so setting Opacity to 0% or hiding bodyparts will not work.
I remember having read something about grouping the Polygons to hide on Genesis and assigning them to a hidden Polygon on the figure i want to fit to Genesis...
Can someone tell me how this can be done?
Thanks in advance!
    You need the Geometry Editor Tool (Alt+Shift+G) Select the tool, right click in the viewport, and select the options that you want. Then select Geometry Visibility from the same menu, then Hide Selected Polygons.
  • Jack238Jack238 Posts: 117
    Hi
    I think you are looking for this post in the forums. I had it bookmarked because I could not remember the steps as I do not use it all that often:
    http://www.daz3d.com/forums/discussion/28138/P375/#451083
    Hope this helps.
  • edited December 1969
    @JimmyC_2009:
    Yeah, I know about Geometry Editor Tool and about hiding Polygons in General... but i want them to disappear automatically when i load the second figure... as far as i remember it got something to do with weight mapped figures that can somehow hide polygons on other weight mapped figures. I`m sure that it is somehow possible...
    @Jack_238
    as mentioned above, grouping polygons and creating surfaces is just a part of my problem.
    Thanks for your replies!
  • Richard HaseltineRichard Haseltine Posts: 111,715
    You need to set the second figure up as a GeoGraft, then add the G2 polygons to its AutoHide group.
