[Released] Desert Ruin (Modular Pack) [Commercial]
3dLab3dLab Posts: 495
https://www.daz3d.com/desert-ruin
Let's explore an ancient ruin in the hot desert.
Desert Ruin is a complete environment with beautiful modular architecture (gate, column, beam, stela, etc.), landscape, and plants.
This project helps you to have a unique, old, ruin experience with realistic modular parts, land, other props.
This set includes sky lighting (render settings) and camera presets to replicate the fantastic promos or get you started creating your own unique scene.
Include desert landspcae.
  • RawArtRawArt Posts: 6,250
    Dropped right into my cart
  • BendinggrassBendinggrass Posts: 1,391
    I am lusting for it right now..... beautiful.
  • caravellecaravelle Posts: 2,799
    Really beautiful. Leptis Magna, Palmyra...
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • memcneil70memcneil70 Posts: 6,195
    cridgit said:
    Can you share a full view of the ground plane please?
    It looks like part of the set but I don't see it listed in the description the top view shows the ruin only. I'd like to see the size/shape of the ground plane as it seems to have some horizon hills.
    I am amazed at the size of the ground. It is huge! The included sky is lovely, but apply it after you use the included render settings, or they will turn off the dome. I have a 1080ti card and this rendered very quickly in less than 2 minutes, 20.8mb. I turned in 360 degrees and couldn't see an end to the view.
     Mary
    1920 x 1440 - 3M
    1920 x 1440 - 2M
  • SummerhorseSummerhorse Posts: 684
    Gorgeous!!
  • 3dLab3dLab Posts: 495
    I added screenshot top view.  I did a huge area Because to make the desert look more realistic. But it isn't a high poly landscape therefore CPU-GPU friendly for renders.
    691 x 703 - 880K
  •  The terrain piece is huge, also you can change texture tiling and the subdivision level to whatever you need. Or slap onto it whatever terrain texture you have as long as it tiles. Great set.
    Yes. You can change texture tiling and thus  you can change the style of the textures .Also you can change desert color.
    Thank you
    Thanks
    Thank you - in the cart!
    Thanks caravelle
    Gorgeous!!
    Thank you
    edited June 2021
     Mary
    Thank you. Yes big landscape but cpu-gpu friendly :D
    Post edited by 3dLab on
