• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
MacOS Bridge 1.2 OSError: [Errno 20]
gene4kagene4ka Posts: 1
June 2021 edited June 2021 in Cinema 4D Discussion
In the console Cinema 4D error
Traceback (most recent call last):  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtC4DWindow.py", line 316, in Command    sss_value, normal_value, bump_value  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/CustomImports.py", line 47, in auto_import_genesis    fbx_path = dtu.get_fbx_path()  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtuLoader.py", line 62, in get_fbx_path    self.load_fbx_path()  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtuLoader.py", line 57, in load_fbx_path    dtu_dict = self.get_dtu_dict()  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtuLoader.py", line 35, in get_dtu_dict    self.load_dtu()  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtuLoader.py", line 26, in load_dtu    for file in os.listdir(self.import_dir):OSError: [Errno 20] Not a directory: '/Users/xxxx/Documents/DAZ 3D/Bridges/Daz To Cinema 4D/Exports/FIG/.DS_Store'>>>
I tested it on Cinema 4d R17 and S22
Post edited by gene4ka on June 2021
  • Razzle-Dazzle3DRazzle-Dazzle3D Posts: 32
    June 2021
    Which install manager did you use to install this bridge? It appears from this error code that the files for this script were installed within to your Cinema 4D R22 plugins folder.  As you are intending to use this bridge with R17, I would recommend uninstalling this bridge via DIM or Daz Connect and then installing this bridge manually.
    To do this for R17, start by downloading the bridge from the Daz to C4D GitHub here:
    https://github.com/daz3d/DazToC4D/releases/tag/1.3.0  -- and scroll to the bottom of the updates listed for this latest release, then download the .zip file for the source code to begin manually installing the folder containing both the Daz Studio and Cinema 4D R17 paths, respectively. Then, unzip this DazToC4D-1.3.0 folder from within the downloads folder (to your desktop), and then install the corresponding files to these locations using File Explorer. Unfortunately, I don't have a Mac OS to test these on, so I'll be listing these instructions for a Windows machine.
    To begin mapping the install paths for this bridge version for Daz Studio, navigate within the unzipped DazToC4D-1.3.0 folder to:
    DazToC4D-1.3.0\Daz Studio\appdir_common\scripts\support\DAZ --> and copy the entire DAZ folder. Then, type "%appdata%" within the top of your File Explorer (please note, if you install DS on another drive, this drive must first be selected); and then within this Roaming folder navigate to:
    Daz 3D --> Studio4 --> RunOnce --> and finally, paste the DAZ folder here (copied earlier from DazToC4D-1.3.0).
    To map the install paths for this bridge version for Cinema 4D, navigate within the unzipped DazToC4D-1.3.0 folder to:
    DazToC4D-1.3.0\Cinema 4D\appdir_common\plugins and copy the entire DazToC4D folder. Then, navigate to within your system files where Cinema 4D version R17 is installed (by default, similar to: C:\Program Files\Maxon Cinema 4D R17) and then navigate to --> \Plugins and paste the entire DazToC4D folder here (copied earlier from DazToC4D-1.3.0). If you do not have a Plugins folder here, create one and paste the aforementioned DazToC4D folder here.
    Once you have place installed these files to their corresponding locations, the Daz to Cinema 4D bridge should now be installed for version R17 and available within Daz Studio under Scripts --> Bridges --> Daz to Cinema 4D.
  • gene4kagene4ka Posts: 1
    June 2021
    Hello! Thanks for the answer. I could not find where to write a bug report, so I wrote on the forum.
    I think that this is not an error of incorrect installation of the bridge from the Daz to C4D.
    I googled and found this explanation on stackoverflow:
    os.listdir() will give you every single file in the directory, including hidden files like .DS_Store.
    It is worth to mention what is the general meaning of the "Not a directory" error (Errno 20). It means that you are trying to operate with a path which sub-path is a real file and not a directory. This error is Unix OS specific.
    I used DIM and manual installation by downloading from github
    I'm sorry it's my fault, English is not my native language, so you misunderstood me.I tested this on two computers, my old computer with Cinema 4D R17 and new computer with Cinema 4D R22 (S22)
    sorry this version doesn't work either
    Cinema 4D R17
    Traceback (most recent call last):  File "/Applications/MAXON/CINEMA 4D R17/plugins/DazToC4D/lib/DtC4DGuiImportDaz.py", line 310, in Command    CustomImports().auto_import_genesis(sss_value, normal_value, bump_value)  File "/Applications/MAXON/CINEMA 4D R17/plugins/DazToC4D/lib/CustomImports.py", line 50, in auto_import_genesis    fbx_path = dtu.get_fbx_path()  File "/Applications/MAXON/CINEMA 4D R17/plugins/DazToC4D/lib/DtuLoader.py", line 66, in get_fbx_path    self.load_fbx_path()  File "/Applications/MAXON/CINEMA 4D R17/plugins/DazToC4D/lib/DtuLoader.py", line 61, in load_fbx_path    dtu_dict = self.get_dtu_dict()  File "/Applications/MAXON/CINEMA 4D R17/plugins/DazToC4D/lib/DtuLoader.py", line 35, in get_dtu_dict    self.load_dtu()  File "/Applications/MAXON/CINEMA 4D R17/plugins/DazToC4D/lib/DtuLoader.py", line 26, in load_dtu    for file in os.listdir(self.import_dir):OSError: [Errno 20] Not a directory: '/Users/xxx/Documents/DAZ 3D/Bridges/Daz To Cinema 4D/Exports/FIG/.DS_Store'
    Cinema 4D S22
    Traceback (most recent call last):  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtC4DGuiImportDaz.py", line 310, in Command    CustomImports().auto_import_genesis(sss_value, normal_value, bump_value)  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/CustomImports.py", line 50, in auto_import_genesis    fbx_path = dtu.get_fbx_path()  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtuLoader.py", line 66, in get_fbx_path    self.load_fbx_path()  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtuLoader.py", line 61, in load_fbx_path    dtu_dict = self.get_dtu_dict()  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtuLoader.py", line 35, in get_dtu_dict    self.load_dtu()  File "/Applications/Maxon Cinema 4D R22/plugins/DazToC4D/lib/DtuLoader.py", line 26, in load_dtu    for file in os.listdir(self.import_dir):OSError: [Errno 20] Not a directory: '/Users/xxxxx/Documents/DAZ 3D/Bridges/Daz To Cinema 4D/Exports/FIG/.DS_Store'
    P.S.  Bridge version 1.1 works fine.
    Best regards, Eugenia
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
