Victoria6 missing dsf files when loading
Fixme12Fixme12 Posts: 589
edited December 2014 in The Commons
Ok,
a thread that's here many times i guess, but can 't find one immediately with a search...
've just installed V6 and sure 've installed genesis2 starterset to
load V6 problem, these files are missing PBMNavel.dsf, Genesis2Female.dsf and CTRLVictoria6.dsf
path example:
/data/DAZ 3D/Genesis 2/Female/Genesis2Female.dsf (checked in explorer and the files are in the folder)
what 'm missing?
772 x 713 - 217K
1999 x 831 - 364K
Post edited by Fixme12 on
  • Fixme12Fixme12 Posts: 589
    ok, problem with naming structure to the folders i guess in content manager,
    what are the correct folders to setup the right path?
    why there are 2 paths needed under dazstudio section?
    and 2 links to paths under poser?
    i tought one link to dazstudio content folder
    and 1 for poser to just the runtime folder...
  • ben98120000ben98120000 Posts: 469
    Install location E:/DAZ3D Content Library/data/... (from first picture) is not the same as E:/DAZ3D Content Library/Daz3d/... or E:/DAZ3D Content Library/My DAZ 3D Library
    You can either add "E:/DAZ3D Content Library" to your DAZ Studio Formats and Poser Formats in the Content Directory Manager or reinstall V6 and G2F to one of the locations listed in Content Directory Manager.
    Post edited by ben98120000 on
    can you give me the right path of the structure then i can figure it out,
    and is it only point to content library or also to the folder where the software is installed as 've got 2 paths under daz and 2 paths for runtime under poser section.
    anyone printscreen?
    Do you use DIM for installations or you do it manually?
    've used DIM
    and did what's written here
    http://www.daz3d.com/forums/discussion/37433/
    So 've created folder DAZ3D Content library (on E drive) as content folder
    My downloads downloaded with DIM go into DAZ3D Content Library/Daz3d Downloads
    the path in dazstudio to content is not correct path.
    so now i changed these to
    DAZ Studio Formats
    Poser Formats
    Now V6 is loading, but i get another file missing
    521 x 355 - 56K
    843 x 618 - 160K
    Age of armour subsurface shader is part of Default Lights and Shaders for DAZ Studio available for download and inatallation as part (but separate installation) of the DAZ Studio "pack" in your product library of your account. V6 uses that shader, so if it is not installed it reports it missing.
    ah since when Default Lights and Shaders split up as separate install?
    been away for a while here so...
    everything runs fine now..., thx for the help!
  • fixmypcmikefixmypcmike Posts: 19,738
    They were split out from Genesis Starter Essentials since people using Genesis in Poser don't need them.
