Correct Eye Material Setup in UE4
Macislav
I'd like to ask if my eye material setup in UE4 is correct or is there something wrong with it. No real and precise information about that topic can be found on the net, so I had to guess how to setup it...
Some materials don't seem to make sense like the Cornea and the Tear Color or the EyeMoisture...
1899 x 877 - 739K
Post edited by Macislav on
Eyesocket-1 needs to use the face texture+normal map + roughness set to 0, but what about the other materials
if you set to 0 it means which they are not being applied at all.
Roughness 0 means maximum wetness.
indeed.
I looked up how the eye materials look like when exported by "the bridge" or how it's called (DaztoUnreal?) and took most of those (esp. the moisture material) node settings/values (mostly some numbers for metallicity, reflection, transparency, roughness, refraction etc.) from there and now it looks much better in most scenes.
