Help identifying hair
evacynevacyn Posts: 993
Does anyone know the hair used in the dForce Lali's Quilted Coat (https://www.daz3d.com/dforce-lalis-quilted-coat)? I thought it was Tamara Hair, but I was way off. Thanks!
  • KrzysztofaKrzysztofa Posts: 226
    It looks similar to the Co Ichigo hair, but honestly I'm not sure.
    The bob hair style that was released today looks close too https://www.daz3d.com/hy-bob-hair-for-genesis-8-and-81-females
    Both of these have the part on the wrong side though.
  • evacynevacyn Posts: 993
    Thanks! I found a few on Rendo that are close, but unfortunately it's hard to tell from photos and the morphs list if they're exact matches. It's odd because I swore I've seen this before, but I guess it's a pretty common look for a bob.
    You know, I just realized it's probably Maltilda Hair
    I did a quick test render, and it looks close. Couldn't figure out how to do the bangs part, but matilda has a ton of dials.
    843 x 823 - 1M
    Thanks again :) It looks like a good candidate but I agree about the bangs. Maybe someone created additional morphs?
  • PitmaticPitmatic Posts: 1,028
    Georgia hair?
  • TaozTaoz Posts: 10,377
    Note that that it is side parted.
  • Seven193Seven193 Posts: 1,156
    You're not looking at all the pics.  It has double buns in the back too, which is nothing like anything in the store.
    The hair with the double buns is a separate hair, most likely https://www.daz3d.com/double-tails-hair-for-genesis-3-and-8-females
    Ah, my mistake.  The promo is using two different hair styles.  The buns is not part of the first hair style.
  • memcneil70memcneil70 Posts: 6,190
    I am not sure about the part, it seems to be in the center, but look at outoftouch's Classic Bob Hair, there are two styling morphs that move the hair to behind the ear and it may be possible to do both at the same time? And the length of the hair is adjustable, so don't discount it based on the main promo image.
  • PixelSploitingPixelSploiting Posts: 898
    edited June 2021
     The short bob hairstyle clearly has an asymmetrical parting so it can't be Matilda hairstyle which I own and I know you can't move the parting to the side. Unless it was changed with custom morphs which is likely for an in-house promo render by a 3d artist.
    This is a very similar hairstyle, although you'll have to get rid of the braids somehow.
    https://www.daz3d.com/rin-hair-for-genesis-8-females
    It could be anything, I'd also look for G3 or in other stores.
    Post edited by PixelSploiting on
    edited June 2021
    I think @PixelSploiting is on to something with Rin hair! I removed the braids and gear via surfaces, and fiddled with some of the shortening morphs. The included white MAT even seems to be a match.
    2000 x 2000 - 2M
    Post edited by Krzysztofa on
    Thanks everyone! I think Run Hair looks the closest so far.
