Problem with face shapes
I have a problem with the shape of the faces of my characters, I had to change the hard drive because it was failing, now that I install a couple of products for example Ann for Victoria 8, the shape of her face is different from the original model, currently I only have Genesis 8 essentials, victoria 8 and ann installed, I leave two photos one before my hard drive failed and another after the new installation. (they are different lights, but the model in theory is the same, first render before the disk failed, second render after a zero install)
1500 x 2063 - 6M
1700 x 900 - 1M
  • Richard HaseltineRichard Haseltine Posts: 111,715
    I'm finding those tricky to compare, but the nose tip does seem different. Do you have similar images for the base Genesis 8 Female? I'm wondering if something you had installed before had a non-zero default value, so it was always in effect and adding to any other shape you applied - because it was at its default it might not throw up an error on loading the scene.
    This is the promotional image, it is more similar to the first image (before the new installation) than to my last render (new installation)
    https://www.daz3d.com/ann-for-victoria-8
    jpg
    jpg
    105K
    Have you installed the two morph sets? They are not part of the Starter Essentials.
