How to turn off or clear L.I.E. FACE BRUISES for Genesis 3 and 8
Anyone know how to turn this off. I applied it to my character but dont like it. L.I.E. FACE BRUISES for Genesis 3 and 8. Thanks so much.
  • prixatprixat Posts: 1,627
    edited June 2021
    I don't know that particular item, but if there is no remove script, you can find the surface and turn it off manually.
    3037 x 1629 - 3M
    Post edited by prixat on
    edited June 2021
    Click the dropdown to get to the Layered Image Editor
    2514 x 1002 - 2M
    In the L.I.E you have a choice of either unticking the layer or deleting the layer.
    3840 x 2160 - 6M
    You may have to repeat the removal for other texture maps, like 'Translucency' and 'Bump'.
  • FenixPhoenixFenixPhoenix Posts: 3,246
    edited June 2021
    I'm attaching a script we have been adding to our latest products to remove the LIE textures from your figure. Keep in mind that this script will indiscriminately strip all LIE from your figure. I believe the face bruises stayed within the face, lips, and ears maps. If so, if you had LIE Tattoos on the torso that you wish to keep, you can select those three surfaces (face, lips, and ears) and click on the script.
    At any rate, I'll submit an update for our LIE products that do not have this script to add it for easy access.
    PS: Thank you for buying our product!
    zip
    zip
    LIE Remover.zip
    48K
    Post edited by FenixPhoenix on
  • fox5050fox5050 Posts: 53
    Thank you so much Im looking Ill look at that when I get home. Thanks for taking the time.
    Ok great that script worked perfect. Thanks sooooo much.
