V4.2, Reality and black eyes!!!
Well the silver lips are gone but now I am getting dark eyes when I have very clear blue eyes designated. Is this a known issue or am I just missing it on the mats this time. No errors or missing files now so I am poking at the problem mat by mat. It isn't specular this time... I will poke about mat by mat unless someone has a work around.
Again, this is an easy fix,
In Reality's material editer open up the materials for V4.2, Select the Cornea meterial, Change the Transmission to Color then set the color to white (255,255,255), Next goto the Modifiers Tab and if there is a Bump Map set then click on the little Gear Wheel and select Detach.
Also make sure that the Cornea is set the Architectural Glass.
You may also have to do the same to the Tear Material if it has one.
The proceedure works for all models, IE. V4.2, Genesis, Genesis 2, ect.
You are a savior!
The black Eyes problem has been around since Reality 2, and in most cases in Reality 4 the problem has been fixed but it still has a tendency to pop up every now and then.
