Do Gen 8.1 shoes work on Gen 8?
i'm looking at this product, which is listed as only for Genesis 8.1 females: https://www.daz3d.com/fashion-basics-paris-runway-heels-for-genesis-81-female-and-victoria-81
Would there be a problem using this on regular 'ol Genesis 8 ladies, or is it only for 8.1? Would there be a problem using it on Genesis 8 females?
Many thanks!
  • HavosHavos Posts: 5,711
    All clothing should work fine on either 8 or 8.1, since it is the same mesh.
  • It might freak out because the Scene Identification might be "Genesis 8.1 Female" instead of "Genesis 8 Female", and then it might force you to autofit.
    (You may have to toggle Scene identification on that prior to putting on the shoes in order to avoid autofit.)
    Other than that, the fit should be identical, as Havos noted.
  • 3dLux3dLux Posts: 1,231
    Took a chance and got Paris Runaway Heels, even though it's for G8.1F and V8.1.  Then tried it in D|S 4.12.
    Here's the result:
    No autofit needed and did some tweaking for the pose but nothing I hadn't done before.
    Fwiw I run both D|S 4.12 & 4.15.
    No buyer's remorse heart yes yes
    1282 x 794 - 431K
