Michael 4 to Genesis 2 Female autofit?
atozedatozed Posts: 77
Quick question. Is there a product that will allow me to autofit Michael 4 clothing to the genesis 2 female? When I try to conform M4 clothing I get a list of source figures that are supported, including V4 and the genesis 2 male, but no M4. A quick search of the store did not turn up anything obvious to me.
  • ByrdieByrdie Posts: 1,783
    First convert from M4 to Genesis, then load the converted clothing and you should be able to autofit to either a Genesis 2 female or male figure. That's how I do it, I don't think there's a separate product required. Some outfits work better than others, for instance you may have issues around the chest area that require smoothing or other tweaking.
    edited December 2014
    There is a way to create autofit clones on your own so that you can make it easier, go here: http://www.daz3d.com/forums/discussion/24093/
    Post edited by cecilia.robinson on
  • almahiedraalmahiedra Posts: 1,374
    If you want use products to go from M4 to G2F, there are two for see:
    M4 directly to G2M
    https://www.daz3d.com/michael-4-for-genesis-2-male
    It is supossed to be better than M4-G1-G2M way.
    It contains M4 Shape, M4 clone with improved autofit to G2M, and M4-UV for G2M
    G2M to G2F
    https://www.daz3d.com/genesis-2-cross-figure-resource-kit
    An alternative way to fit clothes. Some times autofit is better, some times this tool is better.
