dzpropertyeditor plugin fails to load
PorphyrogenitusPorphyrogenitus Posts: 68
Using DAZ Studio Pro 4.7.0.12 I keep getting a plugin load error.
Using the Install Manager (as Administrator), I have tried uninstalling & reinstalling several times and keep getting the same error.
I had been using DAZ successfully up till now. I am not sure when the problem first occurred as I don't check plugin loads all the time.
Plug-in failed to load!
Filename:
C:/Program Files/DAZ 3D/DAZStudio4/plugins/dzpropertyeditor.dll
Plug-in:
dzpropertyeditor
Author:
Unknown
Version:
0.0.0.0
Reason:
Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio.
Unknown
  • Richard HaseltineRichard Haseltine Posts: 111,958
    That shouldn't even be there - Property editor was replace several versions ago with the Property Hierarchy, and Edit mode on the Parameters pane.
  • PorphyrogenitusPorphyrogenitus Posts: 68
    How bizarre that it is showing up then. I noticed it after trying to troubleshoot a problem with the latest update of Reality 4 (c.f. my thread here http://forum.runtimedna.com/showthread.php?95512-Cameras-Lights-Not-Loading-in-Reality-4&p=865336&viewfull=1#post865336 ) - is there a way to get rid of it? Is it related to the problem I'm having with Reality 4.0.4.18?
    It shows up for me, too. It never went away in 4.6 either. After being replaced with the newer plugin, it just stayed in the list.
    It sounds as if something didn't uninstall correctly way back. I don't have that on my system, but I'd had to do a clean install back in July after my HD started to be poorly and seemed about to expire. It may be worth opening a support ticket to report it, though it isn't a critical issue.
  • fixmypcmikefixmypcmike Posts: 19,738
    I don't have that DLL, and I haven't done a clean install since I first installed DS using DIM, so it does sound like something didn't get uninstalled properly somewhere down the line.
