hmm ok a suggestion
father1776father1776 Posts: 982
edited June 2021 in Product Suggestions
1.
At times when I load a pose into a figure, the X/Y/Z arrow widget (that is usually directly under the figure)
will end up far away from the figure making moving the figure in that pose an issue.
My suggestion is to allow customers to 'right click' the widget and choose from a
drop down menu "Unlock'. then you are free to move that widget to a better spot and then 'right click' again and choose lock.
Post edited by father1776 on
  • Richard HaseltineRichard Haseltine Posts: 111,852
    The widget is in the right place, the issue is that the hip has been used to move the figure. In interactive poses that is fine, but in other poses it is not good practice (scene placement should be handled by the figure node) so if they are poses from the store please open a support ticket.
    You can adjust the centre point with the Joint Editor tool, or you could place a null under the figure and parent the figure to that, as ways to address your suggestiion
  • father1776father1776 Posts: 982
    not into dropping a bunch of support tickets on older products BUT
    I like your itea to place a 'null' under the fig and parent it.
    that works for those odd issues.
    THXS
