Yuzuru head morph on Genesis 8 differs from it on Genesis 8.1
If I load Genesis 8 male and drag the yuzuru head morph to 100%, I get this:
https://www.dropbox.com/s/zpxqi34koz8377m/yuzuru8.0.jpg?dl=0
If I load Genesis 8.1 male and do the same, I get this:
https://www.dropbox.com/s/9xhqqcmh2fyg62a/yuzuru8.1.jpg?dl=0
Only the mouth region differs.
Anyone knows what could be causing the issue? Does it happen with you too? I tested some other character heads and the same problem does not happen.
In case someone meets a similar issue, the problem was that, for some reason, when I moved the yuzuru slider on genesis 8.1, some hidden sliders would also be moved and deform the face. I could fix it by setting the option to show the hidden sliders and resetting the ones that were causing the issue
