Genesis 8 Female Anatomical Elements
how do i make it match my character's skin tone please?
  • LeanaLeana Posts: 13,499
    Does the character you're using include textures for anatomical elements?
  • In Daz Land genitals are called 'anatomical elements'. These days the 'anatomical elements' geometry for the particular genesis generation is included with most bundles, previously it was only available if you bought a pro bundle.
    However not all published artists include the 'anatomical elements' textures which are used to match the genitals to characters other textures.
    'Anatomical elements' textures are not provided for underaged characters.
    Other 3rd party genitals are also available.
    Hope this helps
    Steve.
  • AkuraAkura Posts: 41
    edited June 2021
    thank you : ) so the prop does not come with textures? and no the character does not D : should i use another prop : (
    Post edited by Akura on
  • That's correct, the geometry doesn't include the textures and is the same for all the Genesis male and female characters of that generation.
    Look in the characters materials to see if the 'anatomical elements' textures are included, they might be labelled 'Gens MAT' or 'genitals mat'.
    Daz Originals characters always include them unless they are underage.
    Or you can buy 3rd party genitals at another site I can't mention, or else the forum police will delete the thread.
    Try searching for 'New Gens For Victoria 8' using Google.
    Best Wishes
    Steve.
    thank you so very much!!!!
  • DarthDDarthD Posts: 259
    Does anyone offer a simple genital crease morph like the previous genesis characters? I have no interest in the detailed gentials that can be opened and moved around. On the occasions when the lower body is visible on a nude, I just want a simple gen crease. Would be nice if the fibermesh hair would work with it but I assume that is only for the add on gential?
  • nemesis10nemesis10 Posts: 4,008
    As for a simple genital crease, how about Sickleyield's SY 200 morphs which are free?
    edited June 2021
    Here you go, several Camel Toes are in this free package:
    https://www.deviantart.com/mythosarcane/art/Freebie-MA-G8F-Torso-Morphs-02-748238330
    Post edited by Catherine3678ab on
    Thank you nemesis10 and Catherine3678ab
  • Former DAZ CustomerFormer DAZ Customer Posts: 167
    edited June 2021
    There's also a free little mod that allows you to apply the G8F (and theres one for G3F as well) base model UV map to the anatomical elements, after which you can copy the Torso surface to the Gens surface.  Just go through the individual sliders to make sure both have the same other settings; I've noticed sometimes even copying a surface might  leave a setting or two mismatched.
    Search for Cayman Studios torso UVs and you should find it.
    EDIT: the G3F one will work with G8F, just copy/rename the folder to the G8F folder.
    Post edited by Former DAZ Customer on
     All of the fibermesh hairs I've used have parented to the G8F character, not the Anatomical Elements, by default.
    Thank you Gordon Runkle
