In search of hair and clothes
UpiriumUpirium Posts: 728
I want a project so I'm making this game character, but I cannot entirely find what I want.
I need clothes/hair for V4 (NOTHING FOR GENESIS, IT CAUSES BIG PROBLEMS FOR ME)
The clothes will probably be a lot harder than the hair, but I'm going to focus on the hair right now because I can at least make her and have hair for her.
655 x 566 - 153K
700 x 700 - 261K
533 x 720 - 728K
    You might need to do some mix and match but RDNA's
    The Mystix
    Dragongear
    SciWizard
    SolidGear
    The Malaik
    Should give you most of what you need. All are for V4
    Hair: Bridgette, Pinque Curls. Also check out Evelyn and other of Lady Littlefox's older V4 hair sets that are now in Deep Freeze.
  • XenomorphineXenomorphine Posts: 2,421
    Hah! I've been trying to recreate Morrigan, too! :) In my case, Genesis and Genesis 2-based, however.
    The following was something I found in the store which is clearly based on Morrigan's clothing:
    http://www.daz3d.com/nightshayde-for-genesis
    It's designed for Genesis, but might retro-auto-fit. Think there's an ability to do that, these days.
    Not quite been able to find anything applicable for Morrigan's hair or her lower clothing, but you might have more luck with fourth generation figure compatibility.
  • LeanaLeana Posts: 13,502
    There's no retro-autofit to Gen4 figures, only from G2F/M to Genesis (if you have the required clone).
    But IIRC Crossdresser has a Genesis licence, and Wardrobe Wizard probably has one too.
  • pwiecekpwiecek Posts: 1,598
    edited December 2014
    The folds in the neckline of these garments is more subtle than your picture. In fact, if there is a pattern in the texture, they tend to get lost, But they're the best I've seen:
    http://www.daz3d.com/nightlife-v4
    Unfaithful for V4 at rendo
    ADDED LATER
    Also AO5 Euphoria at Rendo
    For a less plunging neckline AO3 Glamour Jeans at Rendo
    Post edited by pwiecek on
    If you are a mage and a female, your spells must be really powerful. Otherwise - in other words, if the enemy isn't scorched to the ground by the first fireball - you will be sorry once the angry minions get to you in what you wear.
    I too think 3DUniverse's Bun Hair would be very close (http://www.daz3d.com/v4a4-bun-hair). It has two buns though and I think Morrigan had one. Natsumy Hair could work, but it lacks the bangs: http://www.daz3d.com/natsumy-hair-for-v4. And for clothes, kitbashing. Check Rendo though. I saw something similar to the Genesis version here.
    Post edited by cecilia.robinson on
  • Scott LivingstonScott Livingston Posts: 4,352
    The Fantasy Collar Set has a V4 version, also: http://www.daz3d.com/v4-fantasy-collar-set
    Any texture sets that are made for the Genesis version should work on the V4 version, and vice-versa.
    For the clothing you'll probably have to do some kitbashing...look through the catalogs of artists like Danie, marforno, Luthbel, Val3dart, etc. - they all have outfits for V4 with a similar look and feel, but probably nothing exactly like that without doing some mixing and matching.
    Post edited by Scott Livingston on
