Easy way to change offset of a follower
Maybe this question is too simple but anyhow.
Sometimes a follower won't play nice with a particular character shape and elements (say a necklace) won't display correctly but are "stuck in the body". Is there an easy way to change the offset/distance of such an element without unparenting it?
    if it doesn't have morphs, you could try a deformer, a tool like meshgrabber or select the item and look under hidden properties to play with the morphs it inherrited when it was fit to the figure
  • LeanaLeana Posts: 13,614
    With a push modifier maybe?
