An error occurred while reading the file
DarthDDarthD Posts: 259
I've been working on a scene for two days, saving regularly. Today, I closed and rebooted my computer. Now the scene will not open.
Is it lost ? The only thing I see is unexpected end of file
Log File
+++++++++++++++ DAZ Studio 4.7.0.12 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.6
OpenSubdiv Version: 2.3.5
Running on Windows 7, Build 7601, Service Pack 1
CPU Information:
CPU String: GenuineIntel
CPU Brand String: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
Cache Line Size = 64
L2 Associativity = 6
Cache Size = 256
Stepping ID = 7
Model = 10
Family = 6
Extended model = 2
CLFLUSH cache line size = 64
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
CPL Qualified Debug Store
Thermal Monitor 2
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
Debug Store
Thermal Monitor and Clock Ctrl
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Self Snoop
Hyper-threading Technology
Thermal Monitor
Pend. Brk. EN.
Physical Memory:
Total: 7.9 GB (8535261184)
Avail: 4.9 GB (5366841344)
Virtual Memory:
Total: 7.9 TB (8796092891136)
Avail: 7.9 TB (8795869429760)
Current Memory Usage: 37%
Current DateTime:
Loc: Thu Dec 11 07:26:03 2014
UTC: Thu Dec 11 13:26:03 2014
Temp Data:
Location = C:/Users/David/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 673.1 GB (722835861504)
Disk Avail: 73.8 GB (79263526912)
Locale: en_US
No translator found.
Creating Plugin Manager...
Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Darkside.style
Creating Import Manager...
Creating Export Manager...
Creating File IO Preset Manager...
Creating Save Filter Manager...
Creating Asset IO Manager...
Creating Image Manager...
Creating Help Manager...
Reading help index
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/EXPExporter/ExPExporter.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/FBXExporter/FBXExporter.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/FigureSetup/FigureSetup.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/graphMate/graphMate.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/JointEditor/JointEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/keyMate/keyMate.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/LAMH/LAMH.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/LayeredImageEditor/LayeredImageEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/Luxus/Luxus.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/MorphLoader/MorphLoader.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/MorphLoaderPro/MorphLoaderPro.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/PolygonGroupEditor/PolygonGroupEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/TextureAtlas/TextureAtlas.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/WeightMapBrush/WeightMapBrush.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
Creating Multimedia Manager...
Creating Authentication Manager...
Creating Content Manager...
Scanning Import folders...
Scanning Content folders...
Creating Render Manager...
Creating Texture Converter Manager...
Creating Texture Baker Manager...
Creating Device Manager...
Creating CallBack Manager...
Using GLEW 1.9.0
Supported OpenGL extensions:
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_blend_color
GL_EXT_abgr
GL_EXT_texture3D
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_SGIS_texture_edge_clamp
GL_SGIS_generate_mipmap
GL_EXT_draw_range_elements
GL_SGIS_texture_lod
GL_EXT_rescale_normal
GL_EXT_packed_pixels
GL_EXT_texture_edge_clamp
GL_EXT_separate_specular_color
GL_ARB_multitexture
GL_EXT_texture_env_combine
GL_EXT_bgra
GL_EXT_blend_func_separate
GL_EXT_secondary_color
GL_EXT_fog_coord
GL_EXT_texture_env_add
GL_ARB_texture_cube_map
GL_ARB_transpose_matrix
GL_ARB_texture_env_add
GL_IBM_texture_mirrored_repeat
GL_EXT_multi_draw_arrays
GL_NV_blend_square
GL_ARB_texture_compression
GL_3DFX_texture_compression_FXT1
GL_EXT_texture_filter_anisotropic
GL_ARB_texture_border_clamp
GL_ARB_point_parameters
GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3
GL_ARB_texture_env_crossbar
GL_EXT_texture_compression_s3tc
GL_ARB_shadow
GL_ARB_window_pos
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_ARB_vertex_program
GL_EXT_texture_rectangle
GL_ARB_fragment_program
GL_EXT_stencil_two_side
GL_ATI_separate_stencil
GL_ARB_vertex_buffer_object
GL_EXT_texture_lod_bias
GL_ARB_occlusion_query
GL_ARB_fragment_shader
GL_ARB_shader_objects
GL_ARB_shading_language_100
GL_ARB_texture_non_power_of_two
GL_ARB_vertex_shader
GL_NV_texgen_reflection
GL_ARB_point_sprite
GL_ARB_fragment_program_shadow
GL_EXT_blend_equation_separate
GL_ARB_depth_texture
GL_ARB_texture_rectangle
GL_ARB_draw_buffers
GL_ARB_color_buffer_float
GL_ARB_half_float_pixel
GL_ARB_texture_float
GL_ARB_pixel_buffer_object
GL_EXT_framebuffer_object
GL_ARB_draw_instanced
GL_ARB_half_float_vertex
GL_ARB_occlusion_query2
GL_EXT_draw_buffers2
GL_WIN_swap_hint
GL_EXT_texture_sRGB
GL_ARB_multisample
GL_EXT_packed_float
GL_EXT_texture_shared_exponent
GL_ARB_texture_rg
GL_ARB_texture_compression_rgtc
GL_NV_conditional_render
GL_EXT_texture_swizzle
GL_ARB_sync
GL_ARB_framebuffer_sRGB
GL_EXT_packed_depth_stencil
GL_ARB_depth_buffer_float
GL_EXT_transform_feedback
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_ARB_framebuffer_object
GL_EXT_texture_array
GL_EXT_texture_integer
GL_ARB_map_buffer_range
GL_EXT_texture_snorm
GL_INTEL_performance_queries : NOT INITIALIZED
GL_ARB_copy_buffer
GL_ARB_sampler_objects
GL_NV_primitive_restart
GL_ARB_seamless_cube_map
GL_ARB_uniform_buffer_object
GL_ARB_depth_clamp
GL_ARB_vertex_array_bgra
GL_ARB_shader_bit_encoding
GL_ARB_draw_buffers_blend
GL_ARB_texture_query_lod
GL_ARB_explicit_attrib_location
GL_ARB_draw_elements_base_vertex
GL_ARB_instanced_arrays
GL_ARB_fragment_coord_conventions
GL_EXT_gpu_program_parameters
GL_ARB_texture_buffer_object_rgb32
GL_ARB_compatibility
GL_ARB_texture_rgb10_a2ui
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_timer_query
GL_INTEL_map_texture : NOT INITIALIZED
GL_ARB_vertex_array_object
GL_ARB_provoking_vertex
WGL_EXT_depth_float
WGL_ARB_buffer_region
WGL_ARB_extensions_string
WGL_ARB_make_current_read
WGL_ARB_pixel_format
WGL_ARB_pbuffer
WGL_EXT_extensions_string
WGL_EXT_swap_control
WGL_EXT_swap_control_tear
WGL_ARB_multisample
WGL_ARB_pixel_format_float
WGL_ARB_framebuffer_sRGB
WGL_ARB_create_context
WGL_EXT_pixel_format_packed_float
: NOT INITIALIZED
OpenGL features for current hardware:
OpenGL provider: Intel
OpenGL renderer: Intel(R) HD Graphics 3000
OpenGL version: 3.1.0
Maximum number of lights: 8
Number of auxiliary buffers: 0
Number of texture units: 8
Depth buffer bit resolution: 24
Maximum OpenGL texture size: 8192 x 8192
Current OpenGL Texture Quality Setting: Good Performance
RGBA color bitplane resolutions: 8 8 8 8
GLSL version: 1.40 - Intel Build 9.17.10.3347
Shadow mapping supported
VBO supported
Creating Asset Manager...
Connected to CMS: 4.8
*** Scene Cleared ***
Loading plug-ins:
aniMate2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzassetiofilters.dll
dzautofit.dll
dzautoriggerbasic.dll
dzautoshaderbakeractions.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcontentdbeditor.dll
dzcontentlibrarypane.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdelightrenderer.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmanualshaderbaker.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzmorphloaderpro.dll
dzobjexporter.dll
dzoptitexclothbasic.dll
dzpolygongroupeditortool.dll
dzprimitives.dll
dzpropertyhierarchyeditor.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzrslshadercompiler.dll
dzsavefilters.dll
dzscriptedrenderer.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dzshadermixerbase.dll
dzshadermixergui.dll
dzsmartcontentpane.dll
dzspotrendertool.dll
dztextureatlas.dll
dztransferutility.dll
dzu3dexporter.dll
dzweightmapbrush.dll
dzwinvideo.dll
graphMate.dll
keyMate.dll
lamhPlugin.64.dll
Luxus.dll
sdk_sceneinfopane.dll
dzdrawstyles.dll
dzpowerpose.dll
Reality_DS64.dll
Total class factories: 1395
Creating Script Engine...
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
Creating Main Window...
Creating Viewport Manager...
Successfully created OpenGL viewport for Viewport1.
Successfully created OpenGL viewport for Viewport2.
Successfully created OpenGL viewport for Viewport3.
Successfully created OpenGL viewport for Viewport4.
Creating Action Manager...
WARNING: libpng warning: Unknown iTXt compression type or method
Creating Pane Manager...
Successfully created OpenGL viewport for AuxViewportView.
WARNING: QFile::flush: No file engine. Is IODevice open?
WARNING: QLayout: Cannot add null widget to QGridLayout/
Executing startup script...
Started in: C:/Program Files/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 1024 Height: 1024
Compiling OpenGL Shader...
Fragment Shader:
No errors.
Fragment Shader compiled successfully.
Linking Shader:
No errors.
Shader Program successfully linked.
Json Parser (6134974,10): Unexpected end of file in object.
Error reading file, see log for more details.
WARNING: fileinput\dzassetdaz.cpp(5456): Unsupported formula: /data/MindVision-GDS/Actual Face Hair/BeardA/BeardA.dsf#BeardA
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/general in file : /data/MindVision-GDS/Actual Face Hair/BeardA/BeardA.dsf#BeardA
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/x in file : /data/MindVision-GDS/Actual Face Hair/BeardA/BeardA.dsf#BeardA
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/y in file : /data/MindVision-GDS/Actual Face Hair/BeardA/BeardA.dsf#BeardA
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/z in file : /data/MindVision-GDS/Actual Face Hair/BeardA/BeardA.dsf#BeardA
WARNING: fileinput\dzassetdaz.cpp(5456): Unsupported formula: /data/MindVision-GDS/Actual Face Hair/Moustache/Moustache.dsf#Moustache
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/general in file : /data/MindVision-GDS/Actual Face Hair/Moustache/Moustache.dsf#Moustache
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/x in file : /data/MindVision-GDS/Actual Face Hair/Moustache/Moustache.dsf#Moustache
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/y in file : /data/MindVision-GDS/Actual Face Hair/Moustache/Moustache.dsf#Moustache
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/z in file : /data/MindVision-GDS/Actual Face Hair/Moustache/Moustache.dsf#Moustache
WARNING: fileinput\dzassetdaz.cpp(5456): Unsupported formula: /data/MindVision-GDS/Actual Face Hair/BeardB/BeardB.dsf#BeardB
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/general in file : /data/MindVision-GDS/Actual Face Hair/BeardB/BeardB.dsf#BeardB
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/x in file : /data/MindVision-GDS/Actual Face Hair/BeardB/BeardB.dsf#BeardB
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/y in file : /data/MindVision-GDS/Actual Face Hair/BeardB/BeardB.dsf#BeardB
WARNING: fileinput\dzassetdaz.cpp(5275): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Genesis.dsf#Genesis?scale/z in file : /data/MindVision-GDS/Actual Face Hair/BeardB/BeardB.dsf#BeardB
File loaded in 1 min 11.2 sec.
Loaded Morph Deltas in 0 min 0.0 sec.
Loaded file: Under Eye3.dsf
Loaded file: Under Eye2.dsf
Loaded file: Under Eye1.dsf
Loaded file: Temples.dsf
Loaded file: Teeth Hide.dsf
Loaded file: Skin Sag.dsf
Loaded file: Side Wrinkles.dsf
Loaded file: Shoulder Drop.dsf
Loaded file: Old Body Straight.dsf
Loaded file: Nose Folds.dsf
Loaded file: Nose Age.dsf
Loaded file: Neck Wattle Single.dsf
Loaded file: Neck Folds.dsf
Loaded file: Neck Detail6.dsf
Loaded file: Neck Detail5.dsf
Loaded file: Neck Detail4.dsf
Loaded file: Neck Detail3.dsf
Loaded file: Neck Detail2.dsf
Loaded file: Neck Detail1.dsf
Loaded file: Laugh Lines4.dsf
Loaded file: Laugh Lines3.dsf
Loaded file: Laugh Lines2.dsf
Loaded file: Laugh Lines1.dsf
Loaded file: Jowls with Sag.dsf
Loaded file: Jowls 3.dsf
Loaded file: Jowls 2.dsf
Loaded file: Jowls 1.dsf
Loaded file: Glute Sag.dsf
Loaded file: Full Spine.dsf
Loaded file: Forehead Folds.dsf
Loaded file: Face Sag2.dsf
Loaded file: Face Sag1.dsf
Loaded file: Eyelid Size.dsf
Loaded file: Eye Socket.dsf
Loaded file: Eye Sag.dsf
Loaded file: Eye Bags.dsf
Loaded file: Ear Big.dsf
Loaded file: Ear Age.dsf
Loaded file: Chin Define.dsf
Loaded file: Cheek Bones.dsf
Loaded file: Centre Fold.dsf
Loaded file: Centre Brow Folds2.dsf
Loaded file: Centre Brow Folds1.dsf
Loaded file: Breast Sag2.dsf
Loaded file: Breast Sag.dsf
Loaded file: BF_TummyOut2.dsf
Loaded file: BF_TummyOut1.dsf
Loaded file: PBMStomachLowerDepth.dsf
Loaded file: PBMStomachDepth.dsf
Loaded file: FBMBodyTone.dsf
Loaded file: PBMGenitalBulge1.dsf
Loaded file: PBMAreolaeDiameter.dsf
Loaded file: FBMPearFigure.dsf
Loaded file: Upper RLateral Incisor.dsf
Loaded file: Upper RCentral Incisor.dsf
Loaded file: Upper LWisdom.dsf
Loaded file: Upper LLateral Incisor.dsf
Loaded file: Upper Lcentral Incisor.dsf
Loaded file: Teeth Size All.dsf
Loaded file: Teeth Angle.dsf
Loaded file: Lower RLateral Incisor.dsf
Loaded file: Lower RCentral Incisor.dsf
Loaded file: Lower RCanine.dsf
Loaded file: Lower LCentral Incisor.dsf
Loaded file: Decay2.dsf
Loaded file: Decay1.dsf
Loaded file: PBMSartorius.dsf
Loaded file: PBMRectusFemoris.dsf
Loaded file: PBMPeroneusLongus.dsf
Loaded file: PBMPeroneusBrevis.dsf
Loaded file: PBMlExtensorDigitorumLongus.dsf
Loaded file: PBMIliotibialTract.dsf
Loaded file: PBMHamstrings.dsf
Loaded file: PBMGastrocnemiusMedial.dsf
Loaded file: PBMGastrocnemiusLateral.dsf
Loaded file: PBMExtensorDigitorumBrevis.dsf
Loaded file: PBMBrachioradialis.dsf
Loaded file: PBMBicepsFemorisShortHead.dsf
Loaded file: PBMAponeurosisExOblique.dsf
Loaded file: PHMTeethTopSize.dsf
Loaded file: PHMTeethIrregular.dsf
Loaded file: PHMEarSize.dsf
Loaded file: PHMEarlobesSize.dsf
Loaded file: PHMEarlobesAttached.dsf
Loaded file: PBMWristThickness.dsf
Loaded file: PBMPectoralsVolume.dsf
Loaded file: PBMLoveHandles.dsf
Loaded file: PBMGlutesUpperDepth.dsf
Loaded file: PBMGlutesLowerDepth.dsf
Loaded file: PBMFeetArch.dsf
Loaded file: PHMAsianMaleBUpper.dsf
Loaded file: PHMAsianMaleALower.dsf
Loaded file: PBMWaistWidth.dsf
Loaded file: PBMUpperArmsVolume.dsf
Loaded file: PBMThighsVolume.dsf
Loaded file: PBMShinsVolume.dsf
Loaded file: PBMKneeBonesVolume.dsf
Loaded file: PBMForearmsVolume.dsf
Loaded file: PBMFeetThick.dsf
Loaded file: FBMPotBellied.dsf
Loaded file: FBMBasicMale.dsf
Loaded file: PHMJawOut.dsf
Loaded file: Regret_09.dsf
Loaded file: Regret_08.dsf
Loaded file: BF_HipSmall.dsf
Loaded file: FBMThin.dsf
Loaded file: PBMAreolaeDepth.dsf
Loaded file: gen-Female.dsf
Loaded file: PBMSacralDimples.dsf
Loaded file: PBMNipplesVolume.dsf
Loaded file: PBMNipplesDiameter.dsf
Loaded file: PBMNipplesDepth.dsf
Loaded file: PBMGluteCreaseR.dsf
Loaded file: PBMGluteCreaseL.dsf
Loaded file: PBMAreolaePerk.dsf
Loaded file: Youth Morph.dsf
Loaded file: FHMGirlFace2.dsf
Loaded Morph Deltas in 0 min 0.1 sec.
Loaded file: FHMGirlFace1.dsf
Loaded file: PHMEyeIrisSize.dsf
Loaded file: FBMBasicFemale.dsf
Loaded file: PHMJawSize.dsf
Loaded file: JCMM5rThighFwd.dsf
Loaded file: JCMM5lThighFwd.dsf
Loaded file: Regret_01.dsf
Loaded file: Open Mouth_01.dsf
Loaded file: JCMM5rThighSideSide.dsf
Loaded file: JCMM5rShinBck.dsf
Loaded file: JCMM5lThighSideSide.dsf
Loaded file: JCMM5lShinBck.dsf
Loaded file: Thigh Thickness.dsf
Loaded file: Thigh Outer.dsf
Loaded file: BF_StraightWaistline.dsf
Loaded file: ManlyMen08.dsf
Loaded file: PHMNostrilsWidth.dsf
Loaded file: PHMNostrilsHeight.dsf
Loaded file: PHMNostrilsDepth.dsf
Loaded file: PHMNoseTipWidth.dsf
Loaded file: PHMNoseTipDepth.dsf
Loaded file: PHMNoseSize.dsf
Loaded file: PHMNoseDepth.dsf
Loaded file: PHMNoseBridgeHeight.dsf
Loaded file: PHMNoseBridgeDepth.dsf
Loaded file: PHMMouthSize.dsf
Loaded file: PHMMouthDepth.dsf
Loaded file: PHMLipLowerDepth.dsf
Loaded file: PHMLacrimalsSize.dsf
Loaded file: PHMLacrimalsPinch.dsf
Loaded file: PHMJawLineDepth.dsf
Loaded file: PHMJawDefine.dsf
Loaded file: PHMJawCurve.dsf
Loaded file: PHMJawAngle.dsf
Loaded file: PHMEyesAlmondOuter.dsf
Loaded file: PHMEyesAlmondInner.dsf
Loaded file: PHMEyelidsUpperHeight.dsf
Loaded file: PHMEyelidsTopInHeight.dsf
Loaded file: PHMEyelidsBottomDefine.dsf
Loaded file: PHMChinWidth.dsf
Loaded file: PHMChinDepth.dsf
Loaded file: PHMBrowDefine.dsf
Loaded file: PBMAdamsApple.dsf
Loaded file: FHMBasicMale.dsf
Loaded file: PHMFaceHeartR.dsf
Loaded file: PHMFaceHeartL.dsf
Loaded file: Head Proportion.dsf
Loaded file: Thigh Smoother.dsf
Loaded file: ThighStraight.dsf
Loaded file: ShinsStraighten.dsf
Loaded file: PubicAreaOut.dsf
Loaded file: LegShape2.dsf
Loaded file: PBMWachiwiGenitals.dsf
Loaded file: CTRLBreastsNatural.dsf
Loaded file: NoseShape5.dsf
Loaded file: LacrimalYoung.dsf
Loaded file: PHMFaceYoung.dsf
Loaded file: PBMStomachSoften.dsf
Loaded file: PBMNipplesSize.dsf
Loaded file: PBMNipplesLarge.dsf
Loaded file: PBMNavelVertical.dsf
Loaded file: PBMNavelSize.dsf
Loaded file: PBMNavelDepth.dsf
Loaded file: PBMNailsLength.dsf
Loaded file: PBMHipSize.dsf
Loaded file: Young Breast2.dsf
Loaded file: Adult Proportions.dsf
Loaded file: FHMVictoria6Head.dsf
Loaded file: FBMVictoria6Body.dsf
Loaded file: JCMM5lShldrUp.dsf
Loaded file: JCMM5lCollarBendUp.dsf
Loaded file: PHMFrown.dsf
Loaded file: PBMDeltoidFlexL.dsf
Loaded file: FBMMichael4.dsf
Loaded file: FBMMichael5.dsf
Loaded file: Part 1 Scene 20 A Stroke Of Genius.duf
Saved image: C:\Users\David\AppData\Roaming\DAZ 3D\Studio4\temp\d68.png
Saved image: C:\Users\David\AppData\Roaming\DAZ 3D\Studio4\temp\d70.png
Saved image: C:\Users\David\AppData\Roaming\DAZ 3D\Studio4\temp\d71.png
Saved image: C:\Users\David\AppData\Roaming\DAZ 3D\Studio4\temp\d72.png
Saved image: C:\Users\David\AppData\Roaming\DAZ 3D\Studio4\temp\d209.png
Loaded file: PHMLipsPucker.dsf
Loaded file: PHMLipBottomDownR.dsf
Loaded file: PHMLipBottomDownL.dsf
Loaded file: PHMBrowOuterUpR.dsf
Loaded file: PHMBrowOuterUpL.dsf
Loaded file: PHMSmileSimpleR.dsf
Loaded file: PHMSmileSimpleL.dsf
Loaded file: PHMNostrilsFlare.dsf
Loaded file: PHMLipBottomOutR.dsf
  • DarthDDarthD Posts: 259
    When I reopened Daz my workspace layout was changed also. Since the upgrade to 4.7 it has crashed four times. Never had an issue with previous version.
    Oh well. I guess no one knows
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,832
    I have no idea but since the errors seem to involve actual face hair you could try seeing if that loads ok first
