problems installing to D drive
DiomedeDiomede Posts: 15,470
Recently had to have my laptop repaired and they wiped my hard drives. I need to reinstall all of my Daz programs and content. I am starting with Daz Studio.
I do NOT want my stuff installed to my C drive, I want it installed to my D drive. I downloaded DIm and installed it to a folder in the D drive called stuff for Daz. I also created dedicated folder on the D drive for Daz Studio(and for other Daz programs and content but they have not come up yet).
I installed Daz Studio 4.7, genesis starter essenials, and the starter essentials for G2 male and G female. I get an error trying to load a figure in studio. I have posted screenshots of the error. It says it can't find .dsf files in the data directory.
I am using Windows 8.1 64 bit.
1275 x 908 - 127K
1246 x 830 - 113K
550 x 519 - 39K
552 x 516 - 50K
  • SimonJMSimonJM Posts: 6,108
    What version of Daz Studio? It should be trying to load a .duf file (it was .dsf until a version or two ago). You can change what loads on startup under Preferences (Edit> Preferences or press F2).
  • DiomedeDiomede Posts: 15,470
    Thanks for your prompt reply. It is Daz Studio 4.7, 64 bit. No idea why it is looking for .dsf files if it isn't supposed to be.
  • fixmypcmikefixmypcmike Posts: 19,742
    The problem is that you told DIM to install things to the D: drive, but you haven't told DAZ Studio where to find content. In DS go to Window > Preferences > Content Library > Content Directory Manager and add "D:Stuff for DAZ\Stuff for Studio" under BOTH "DAZ Studio Formats" and "Poser Format", and remove the two default locations.
    Thank you very much. That fixed it. I will now attempt to install my other content. Might be back with more questions. :-)
  • Richard HaseltineRichard Haseltine Posts: 112,021
    You don't want to have the 32 bit and 64 bit software paths the same, as they are in your first screenshot - if they are, and you install both, one will overwrite the other (or worse, partially overwrite the other).
    Ouch. If I have only installed one version of Studio, one version of Carrara,..., do I still need to start over?
    No, though if they are both 64 (or both 32) it would be a good idea to change the path you haven't used.
