Can't find installed files
Hi -
I just purchased the be seated poses
https://www.daz3d.com/be-seated-for-her
I used DIM to install this. I cannot find the files anywhere. DIM shows they are installed
Z:/DAZ3D Studio/Content/My DAZ 3D Library/People/Genesis 3 Female/Be Seated
I cannot find this path at all.... How do I fix this?
thank you
  • NorthOf45NorthOf45 Posts: 5,921
    edited May 2021
    Try to click a pose file in the "Show Installed Files..." dialog from DIM. If it's a blue hyperlink, it will open a file explorer window at that location. Note that the path is not the *standard* "People/Genesis 3 Female/Poses/Be Seated". Is the Z:/DAZ3D Studio/Content/My DAZ 3D Library/ your usual installation path? You should see all your other products there, too.
    Post edited by NorthOf45 on
  • KeithHKeithH Posts: 338
    Yes that is my install path. But that's my point - no files show in DAZ and there are no files install on my HD but DIM says it installed everything. Frustrating.
    OK -
    I found it - not under the pose dir at all it is right under the g3f female dir.
