Victoria 4 texture on G2M?
JUJUJUJU Posts: 1,133
Hi!
Is there an easy way to use V4 textures on G2M?
Thank you very much
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,737
    edited December 2014
    if you own Mallenlane's V4 for G2F you can copy over the UV in data to G2M
    save tthe V4 loaded on genesis as a material duf preset on genesis and load that on G2M
  • Richard HaseltineRichard Haseltine Posts: 111,859
    If you have Victoria 4 for Genesis 2 Female and your V4 textures saved as a Materials preset they should just apply to G2M - the UV set will be loaded correctly from the G2F data folder.
  • superheroinsuperheroin Posts: 6
    there is a desire to create a plug-in for use tekseur and morphs models from 4 generations .... I have a lot of good models from third-party developers ... would like that they were working with models 6 generations.......
    I am sorry for my bad english
    Post edited by superheroin on
    Take a look at GenX 2
    http://www.daz3d.com/genesis-generation-x2
    This plugin allows you to transfer morphs from Generation 4 to Genesis and G2F/M
    At the very least, you will need the M4/V4 shapes for Genesis
    http://www.daz3d.com/v4-and-m4-shapes-for-genesis
    And the Generation 2 plugin for GenX
    http://www.daz3d.com/genx2-addon-for-genesis-2
  • TimbalesTimbales Posts: 2,457
    If you are a Studio user, you can use the Map Transfer utility with Genesis to remap V4 UV to M5 UV, which G2M accepts.
    thanks for the info ..... another question: is it possible in version 4.7 isolzovat video as a texture and that it needs to
