MRL dForce Long Layered Hair for Genesis 8 Female - Not Rendering
Hey folks.  Curious if anyone has had a problem where MRL dForce Long Layered Hair for Genesis 8 Female doesn't render in 4.15.  I can't get it to work on any G8 models at all.  It shows up in texture shaded mode but will not render.  Any tips would be appreciated. Thank you!
  • memcneil70memcneil70 Posts: 6,145
    First check your cursor style. Tool and another (can't think which one) causes issues. Also, see if the hair has a on/off thumbnail or a selection in Parameters to adjust.
    Thanks for the tip.  I tried changing various tools and that had no effect.  Didn't find the setting you mentioned in the Parameters panel.  I did verify that the visible in render toggles are ON for both the cap and the hair.  Still no render.  Odd thing is that it shows perfectly fine in the viewport shading modes.  All but iRay.
    p.s.  I started this scene fresh and didn't modify any of the default render settings.  It's all just vanilla stuff out of the box.
    It's dForce hair (not to be confused with cloth dForce), so it won't show up in the preview unless you turn on the preview option.
    Do you mean "Preview PR Hairs" on the MRL DFLL Hair object?  If so I toggled that on and they still don't show up but I did do a test output render and the do show up so that's good.
    The Line Tessellation also has to be set above 1 in order to show up.
    That did it!  Thank you so much for your help.  Learning something new in Daz every day lol.
