Daz 4.7 Where is the Subsurface tab?
jodycourjodycour Posts: 137
I downloaded the New Daz3D 4.7 It works great but I use to pull up the Subsurface tab when I click on all it enabled me to pull up the colors. Then I was able to change the color of any object that I've selected, now I can't do that!
What do I need to do now to do the same thing?
  • Richard HaseltineRichard Haseltine Posts: 112,037
    There isn't a subsurface tab. There is a Surface pane, which allows you to edit settings for the material on a selected surface, including the Subsurface scattering settings if the shader used has them. Window>Panes(Tabs)>Surface, use the list in the pane or the Surface Selection tool to select the area or areas to work on.
  • jodycourjodycour Posts: 137
    Thank you very much that helped! Is there anyway to make this available like it use to be?
    You can dock the pane - drag the tab into another group of panes. With the viewport (which is itself now a dockable pane) is one possibility.
