Trouble applying Iray shader to OBJ
Using a 3rd party OBJ of a crumpled rag, I tried to apply an Iray lace fabric shader, but all I get is a solid, shiny surface instead of a lace pattern. I've never had this issue before. I did try varying the horizontal & vertical tiling by quite a bit, but get the same results every time. The image provided shows a standard primitive plane on the left and the OBJ on the right Top is NVIDIA viewport and bottom is wireframe view.
1309 x 1474 - 1M
  • GordigGordig Posts: 10,802
    Does the OBJ have the Uber base shader applied? If not, you'll need to apply that before the preset.
  • mikethe3dguymikethe3dguy Posts: 515
    Yes it does
  • MelanieLMelanieL Posts: 7,867
    Is the OBJ UV-Mapped?
  • zombietaggerungzombietaggerung Posts: 3,941
    The crumpled rag probably isn't UV unwrapped. Which means it cannot properly display any image map, so it will only show a solid color.
    A-ha. Thanks - any way to fix this?
    I downloaded UVmapper and created a UV for it. Just trying to figure out how to apply it to the object...
    Well, I would import the obj into Blender and UV unwrap it there then re export the unwrapped obj out and into DS. Since it's a funny shape, I'd use the Smart UV Project option in Blender.
    You don't have to "apply" it. Just re-export the now UV unwrapped object out of that program and import it into DS. then apply the shader as before.
    Ah, beautiful, worked like a charm - thanks!
    Glad to help. yes
