What's the difference between base resolution level and high resolution?
ps2000ps2000 Posts: 278
I changed the resolution level of a character from high to base resolution to avoid poke through after adding a smoothing modifier to some clothing.
It worked. But does my character now look worse (because of the lower resolution)? I couldn't see a difference in the render.
Thanks
  • GordigGordig Posts: 10,797
    Depends on a lot of factors, such as how far the figure is from the camera, and what kind of morphs you're using. If it looks fine to you in the render, that's all you really need to know.
