Compare Carrara 8.5 and ..8.5 Pro?
AD_639100AD_639100 Posts: 396
Hi,
can I see somewhere the different between Carrara 8.5 and Carrara 8.5 Pro?
Thank you for information.
Greetings Conny
  • DUDUDUDU Posts: 1,945
    Previously there was a table of comparison on the site DAZ, it seems that they gave up all the softwares except Studio !
    I finally found on google a trace of Carrara on the site: only one price difference…
    Personally for the small price difference (for the moment), I would jump on the version “Pro”!
  • AD_639100AD_639100 Posts: 396
    Hello DUDU_00001,
    thank you for your answers. I bought today Carrara 8.5 Pro version.
    Have a nice weekend.
    Greetings Conny
    Conny1000 said:
    Hello DUDU_00001,
    Greetings Conny
    Good choice!
    You will not have any frustration not to have a specific option.
    Here's a link to Carrara 8.5 Pro features for anybody else that comes across this thread with the same question:
    http://www.daz3d.com/carrara-8-5-pro
    The big things that Carrara Pro has that the standard version does not are:
    64 bit version.
    Render Nodes for network rendering.
    More Import/Export options.
    Ocean Primitive.
    I think that Render Passes may also be a Pro feature, but I'm not 100% sure on that anymore.
    There are some more Pro only features but without the comparison chart I'm not sure what they are.
  • thoromyrthoromyr Posts: 452
    render passes at least used to be pro only. Some of the modeling room features, like bridge, are pro only. I started on standard and didn't take long to need pro features -- should've just bought pro in the first place...
    That is usually my advice as well. If you have a couple extra bucks, go for the Pro version.
    64-bit alone makes Pro worth getting, since you won't be constantly running out of memory and resources (standard can only access 3GB, no matter how much RAM you have installed).
    I made that mistake a year ago, buying Poser10 instead of Poser2014 (and that's a lot less product for a lot more money...)
    Thanks a lot for all these interesting points, in particular the differences between the various versions. Have a Merry Christmas and thank you again for the support.
    Greetings Conny
