converting cr2 to hr2?
roxynightroxynight Posts: 0
Hi,
does anybody know if there is a way to convert cr2 files to hr2? I'd like to use my V4 hair props for genesis 2 and this only seem to work right with hr2 files. The autofit tool does not really help, it totally messed up the geometry :(
  • fixmypcmikefixmypcmike Posts: 19,738
    Instead of fitting the hair to Genesis, parent it to Genesis' head, and use the translate, scale, and rotate dials to fit it. You can also add a smoothing modifier after getting a close fit to push any parts of the hair that are inside the head out.
  • roxynightroxynight Posts: 0
    edited December 2014
    This is my usual workaround but i thought there might be an easier way. however - thank you :)
    Post edited by roxynight on
  • pwiecekpwiecek Posts: 1,598
    Hi,
    It can be done. With a lot of work, you can transfer any morphs, but any posing capability will be lost. hr2 is a prop.
    pwiecek said:
    Hi,
    Thank you very much for the answer! Seems like the workaround is the easiest way then:)
