Any Way to Stagger Position of Objects Without Manually Entering Position of Each?
Is there any way to select a bunch of objects and stagger them apart without manualy setting each one's position. By this I mean selecting them all and entering something like 10 in the x translate property and each object or node being progressively 10 apart in the x direction.
  • MartirillaMartirilla Posts: 193
    I've never had need to use it yet, but I see that UltraScatterPro for Daz can "create a matrix of instances". There another Daz script that can then do the "instances to props" conversion, if you need props.
  • AscaniaAscania Posts: 1,856
    Use the Align tool.
  • 3dward3dward Posts: 32
    Use the Align tool.
    Thanks.
