render of artwork of image the out side is white
rigomrtsfxrigomrtsfx Posts: 103
hi
when i render any artwork the boarder just out side of the artwork is white
it use to be black or gray in older versions , how could i change it
please thank you for your time
  • Richard HaseltineRichard Haseltine Posts: 111,738
    What are your render settings, and in what format are you saving the render?
  • fixmypcmikefixmypcmike Posts: 19,731
    Window > Pane > Environment allows you to set the background color or image for the render, or to render as an alpha channel.
  • Arnold CArnold C Posts: 740
    edited December 2014
    If you save your art in a .png format, the backgrund color will always be white in the Windows Picture Viewer, regardless if you used a backdrop or changed the viewport color. Using a different Picture Viewer the backdrop/color will be shown, depends on the software used. Same will be if you set your art as a wallpaper for your desktop. The thumbnail although will still be shown white. Seems to be more a problem of the standard picture viewer Windows is shipped with.
    If you choose to save it in a .jpg format, the backdrop, if used, or a different viewport color chosen will be shown in the Windows Picture Viewer.
    Post edited by Arnold C on
  • rigomrtsfxrigomrtsfx Posts: 103
    thank you so much
