Install Manager question, could not find answer.
jcleaver42jcleaver42 Posts: 10
I just downloaded Install manager, and then downloaded all 2000 + items for Poser, DAZ Studio, Bryce, Carrara, etc.
I did not have it install anything yet, as i want to make sure of functionality first.
My question is this: Will Install Manager automatically install Poser Files to Poser and DAZ Studio Files to DAZ Studio if i batch install everything at one? Or do I have to filter for each application and install those seperately?
In a nutshell, I would like to click on install with everything checked and have the products installed to their correct locations.
Thanks!
John
  • frank0314frank0314 Posts: 15,098
    You have to select where to install it to. You need to direct it to your Poser runtime. You will also need to add poser to the installation tab.
    553 x 518 - 101K
  • jcleaver42jcleaver42 Posts: 10
    OK, I have the paths set up already.
    What i take from your reply is that what I want to do is not possible then. I have to pick Poser Files and DS files separately.
    Correct. You can however right click over any pack and select "Select Packages" and then select Poser and it will filter all the packs that are tagged Poser. Then you can install the lot of them.
    Thank you very much! That makes it work for me.
  • Richard HaseltineRichard Haseltine Posts: 111,348
    You don't have to place the files in separate locations if you don't want to - that saves doubling up texture files, if nothing else.
