'Select All' Issue- I may have discovered why it does it!
dash2128
A lot of work is (constantly) lost when the hated (by those it plagues, at least) 'select all' feature selects everything, and causes the computer to either freeze, or run so long that it has to be shut down.
After not being able to discover why the mouse was causing this, ...when it did it today, a small 'right-click' box appeared (for just and instant!- never had, before) with 'select all' at the top- highlighted!
Perhaps this command- 'select all'- should NOT be placed at the top of the list! Some benign command would be okay. This might end the issue.
Can an update resolve this problem? Place the 'Select All' command in a benign place?
That would be great, because I would really like this issue to just...go away!
Knowing what is probably causing it, doesn't help me stop the problem, however.
...other than the suggestion made above.
I believe someone recently said they were experiencing a similar problem, though.
Redacted
A 'drag-select' issue, that sounds correct. Wish I could disable it- or 'select all', completely. I've only required the feature, twice, and each time it didn't accomplish what I needed it. But the endless times the software has cost me work, by 'selecting-all', when I didn't want it too....
You mentioned 'deliberate steps', that seems to be the issue, in my case. It 'selects all' when I did not make deliberate steps to do so. I wonder if others use the feature much, or if it's just in the way.
Only certain items are good for grouping, smart content is better used for grouping and then associating something to that group, old content has issues when grouping 5 items in the file tree and say parenting them to a part all at once. The select all issue happens every now and then probably because the scene is heavy and you did something in lag you held the button too long and lag grabbed it, when you depressed the button it was still enaged due to system slow down hence selecting all in a drag motion when you moved away at pace and it lag clicked everything on. This happens in gamming too when your system is suffering lag spikes due to internet speeds or your memory being used in excess.
I imagine these things wil no longer happen once the UI version upgrade is complete (though a lot of other things will start to happen!).
Actually, that sounds logical. ...like whatis happening. ...wish it didn't, though.
