A Couple Of Questions
Faeryl WomynFaeryl Womyn Posts: 3,775
#1
Does the RSSY iRay to 3DL not convert a single item? For example, I want to convert the textures of a pair of boots, I select them in the scene and surfaces tabs and run the RSSY, clicking the buttons I need to and let it do it's job, except for some reason it doesn't convert the boots, but converts my characters textures, which are suppose to already be 3DL and makes them look really bad.
#2
I've been using the same computer for the past 7 years, so there should be no difference between versions when it comes to rendering. When ever I did renders before, after converting things, it would take anywehre from 10 minutes to half an hour. Since using 4.10  and 4.12 and now it takes over 2 hours, and that's without any iRay in the scene, even old stuff is doing this. Is this normal?
#3
If you're using Gen4 models with Gen4 textures and lights and everything else old, why am I getting noise when I render? It's never done that before.
Post edited by Faeryl Womyn on
