CPU or GPU mode indicator in Render float
pixelquackpixelquack Posts: 433
edited May 2021 in Product Suggestions
[CPU or GPU mode indicator in Render float] Or even better: state how much vram the scene is using right now so we know by hoch much we blew it. Yes it's in the log, but really, simply field with a number.
And then: Render Queue - the app. So I can watch progress from elsewhere.
  • Richard HaseltineRichard Haseltine Posts: 111,792
    Iray Server is the render queue, I would think.
  • pixelquackpixelquack Posts: 433
    Come again?
    Your suggestion wasn't clear, but if you are wanting a way to queue renders outside DS then I would think you would be looking at Iray Server.
    My suggesti--- in the popup window that displays render progress, add a field that says "rendering on CPU" or "rendering on GPU" so we know if we've blown the VRAM of our GPUs.
    Cherry on top: display in a dedicated field how much VRAM the scene does use, actually.
    Is that comprehensible? I can make a mockup, too.
    Forget the "render queue" bit. That's beyond Daz' tech.
