Where is Genesis installed in DAz studio 4.7?
Dave_1043192Dave_1043192 Posts: 207
I decieded to have a hard drive clear up and installed DAZ studio 4.7 and removed version 4.6 .I have a couple of items that throw up an error message that says "such and such is an add on for Genesis and they must be installed in the same location" most Genesis stuff is working just fine so i assume Genesis must be installed everything was installed to default location and Ive trie to install to C:\Users\[Your User Account]\Documents\DAZ 3D\Studio\My Library as that seems to be were the default location should be for windows 7 .Any one know where Genesis is? that its looking for?
    If you used DIM (DAZ Install Manager) to install Genesis Starter Essentials, it will be installed by default into :
    C:\Users\Public\Documents\My DAZ 3D Library
    If you only upgraded to 4.7 from 4.6, nothing should have changed as far as your content is concerned though. Just check that the path locations to the content are correct in Edit > Preferences > Content Library > Content Directory Manager.
  • Dave_1043192Dave_1043192 Posts: 207
    Tried that but it still gave an error so Im redownloading and installing Genesis Starter Essentials see if that helps
    No that still dosnt work
  • Richard HaseltineRichard Haseltine Posts: 112,021
    Which are the items, and is this when installing or when using?
    strigoi the ancient vampire the problem is trying to install it
    It may be looking for a file that has been changed since the installer was built - get the latest, zipped, version.
