Possible to temporarily trick DAZ into thinking G8.1F has no fittings? (Eyelashes, Tear, Clothing)
I have G8.1F and it has a bunch of things fitted to it, like eyelashes, tear, eyebrows, clothing, shoes, hair, etc.
In DAZ 4.15.0.2, if I try to send G8.1F to Zbrush, VIA GOZ, with its fittings, only the fittings (clothing, hair, lashes, etc) will be sent, but G8.1F does not get sent to Zbrush. This was fixed in DAZ 4.15.0.14, but this updated version is completely unstable and crashes constantly on render, it has so many problems it's no where near useable for production.
Is it possible to temporarily trick DAZ into thinking G8.1F has no fittings? Even though it does? G8.1F gets sent to Zbrush just fine if it has no fittings.
EDIT: I figured it out. Select all the fittings of G8.1F, so they're all selected. Click ---> Edit ---> Figure ---> FIT TO ; that will allow multiple fitting and unfitting. So you can rapidly unfit all the items, send ONLY G8.1F to Zbrush via GOZ, then have it come back. Then refit everything again simaltaneously after using that FIT TO function from the edit;figure menu.
