Weird Green lines from skin grafts/anatomical elements
This weird green line keeps appearing around skin grats/anatomical elements (sorry, not sure of the terminology). I think its the same thing as if you duplicate a character and their skin intersects, it's like definition/highlight?
Nothing I can do within Daz seemingly gets rid of it. HOWEVER if I change Daz's layout/style from "window" options - it no longer displays, as you can see in the lower half of the image. It's very weird.
Restarting Daz doesn't help. Only switching styles whenever the issue (randomly) reappears.
  • IceCrMnIceCrMn Posts: 2,332
    edited May 2021
    looks like it's happening around the shoulder/arm area also.
    The glossy effect is different there in your your screen shots.
    Maybe it's the Dual lobe specular weight setting isn't the same for all the skin surfaces?
    I think that seam is a problem with SSS.
    Try adjusting the SSS direction to -1 and see if it goes away or the effect is reduced.
    edit:Setting the SSS Direction to -1  or 1 seem to be the only settings I can use that don't produce that seam.
    That normally fixes it for me.
    Post edited by IceCrMn on
  • Thanks IceCrMnheart It was a huge help for me. This method reduced the seam exponentially. (about 85-90% almost invisible)
    This is the best solution so far.
