objects in mirror closer than appear
You read the title. I've been fiddling with the knobs in Studio for a while and I still can't figure out how to change the size of an object in a mirror- ideas?
  • TheKDTheKD Posts: 2,711
    You mean like an actual reflection? I think the only way to do that would be to curve the mirror object like a parabolic mirror. Assuming you mean iray, the reflection is gonna happen close to how it does in real life.
  • Richard HaseltineRichard Haseltine Posts: 111,734
    Focal length of the camera would also play a part.
  • charlescharles Posts: 866
    edited May 2021
    Camera distortion, inv poly 3, K1 (experiment)
    But if this is a mirror in the scene and you just want the mirror part to be effected, then you'll need to change the geometry on the mirror to be a parabolic, you can try using DForm on it and give it a bulge.
    Post edited by charles on
