dForce Ventilator
MescalinoMescalino Posts: 436
edited May 2021 in The Commons
So i have a character with a dForce duster. This all works fine.
Now i want to create wind so the bottompart is blownin the wind. I created a ventilator asuming this is what is for but i cant get the desired result.
It looks like it blows wind then halfway stops blowing.
Is there a tutorial or a trick i am missing?
Thanks
After some extensive search i found:
Post edited by Mescalino on
  • RGcincyRGcincy Posts: 2,864
    edited May 2021
    If you are talking about the dForce wind node, thee are falloff zones for both diameter and length which may be playing a role. If you could post an image of your viewport with the wind node selected and in the parameters tab set all the opacity parameters to 100% (so all the zones are visible) that would aid providing help. In the meantime, a couple of examples:
    Wind Node
    Creating Blowing Curtains
    Flying Cape
    Post edited by RGcincy on
  • MescalinoMescalino Posts: 436
    Wind Node
    Flying Cape
    Thanks for your reply. I Have it working now. The fall of zones in combination with a way to low wind M/Ph setting was the problem.
