Zombie for Genesis and M4
mwokeemwokee Posts: 1,275
Can you create the zombie figure without the pants or is it always pants-on?
Thanks
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,581
    depends how scary a stiff we are talking about :lol:
    It would probably need to be at least partially covered, even if only with rags, in order to pass the ToS
  • mwokeemwokee Posts: 1,275
    I actually want to use it as a cadaver so it's not going to work if it's always pants-on. So I need to know the answer to that before purchasing.
    I'm not responsible for artistic interpretations from the peanut gallery. :)
    depends which zombie you mean, all have pants only as clothing so nude by default but no gens unless you buy pro bundle for Genesis
    Well... "Zombie for Genesis and M4" is the one I am interested in.
    Can the figure be created without the pants? The promo pictures all have clothes on so it's difficult to tell if the pants are optional.
    The scene I want to create is a cadaver in the Westpark Morgue.
  • kaotkblisskaotkbliss Posts: 2,918
    Zombie for Genesis/M4 as well as Long time dead are all clothing-optional
    Zombie for Gen/M4 are new skins for the figure (so it removes the default shorts that M4 wears)
    Long time dead has both a skin for Gen2 as well as a full figure
    It also lets you dial in the amount of Zombie you want on a figure and I found just a touch can turn a Gen2 figure into an old man :)
    Thanks kaotkbliss, that's the answer I needed!
    Unless a texture set specifically says it contains texture maps for the genitals it is best to assume it does not.
