Face Controls Rotating Entire Head
Hi, All
When I load the G3/8 Face Controls, the controls rotate the entire head. The controls are not effecting the associated face elements. What am I not understanding? Here are the steps I've done....
1. Load Genesis 8.1 Female
2. With the character selected, load the face controls
3. Face controls appear on character's head.
4. When I select a control and attempt to move it, the entire head rotates with the control movements
Any help would be greatly appreciated.
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,922
    Are you clicking to select the control, then clicking again to move it?
  • wildbillnashwildbillnash Posts: 784
    She's possessed, devilcall an exercist.
  • gandokgandok Posts: 0
    Thanks for the response. Your suggestion stops the head moving, but the expression doesn't move. I tried several controls, nothing moves.
    Are you using the gizmo (the control handles on the selected node)? Just dragging the node itself won't do anything, that is used with IK chains.
    Richard,
    Thank you. I figured it out. I wasn't sure what you meant by "gizmo". After 10 minutes of playing, I realized the movement is controlled by the 3D arrows that pop up after you select the node controls (circles, halfmoons, arrows, etc). This is likely what was meant by gizmo. Thank you for your responses, they were helpful and appreciated.
    Happy rendering.
