Selecting a render camera in DS 4.7?
AeonicBAeonicB Posts: 166
edited December 2014 in Daz Studio Discussion
I've been kind of out of the loop with DAZ since version 2 something or so, so forgive me. I'm primarily a Carrara user, anyways. :)
I can't find a way to let DAZ use a Camera as a viewpoint for rendering. Whenever I try to render, it only renders from the Perspective View, even if I'm looking through another camera in the viewport, not the Perspective View angle.
This is bugging me, since I just bought AoA's Atmospheric cameras, and I kind of, you know, want to use them.
Thanks for any help, it's much appreciated. :)
Post edited by AeonicB on
    It should render through the active view -- check that the Auxiliary viewport isn't using a different view.
  • Richard HaseltineRichard Haseltine Posts: 111,315
    Are you sure the viewport you have changed the camera in is the active viewport - if you have a divided viewport, or the Aux Viewport open in 4.7, it may not be. Try right-clicking in the viewport you want o render, to get the menu, then press Esc to clear it and then render.
  • AeonicBAeonicB Posts: 166
    It is-- I'm using only one pane, with my view looking through the fog camera.
    Which fog camera? At least some parts of the Atmospheric Effects Camera ar reportedly not working correctly in DS 4.7.
