Iray; Speeding up Animation Render, specifically the "load in"
So, I have an animation that I'm rendering where every frame takes about 17 seconds to render, a couple of characters, two genesis 8s and some rocks as a landscape.
My problem is, I measure it and it takes about six and a half seconds before the iray iterations start, which, across 1000 frames, adds up quite a lot.
If I understand correctly, it looks like DAZ Studio is loading in the geometry and materials data to the gpus every single frame? Is there any way to speed this process up?
If there's no software settings to affect, what hardware is bottlenecking that part of the process in case I think about upgrading? I have a multi-gpu setup that I've invested a lot into and I want to not have it bottlenecked if at all possible.
  • margravemargrave Posts: 1,822
    Daz Studio uses the Iray render engine, which is proprietary to NVIDIA. As I understand it, feeding geometry and texture data to Iray through its API isn't something they can optimize, since it's not their source code.
  • DiasporaDiaspora Posts: 552
    That's understandable, but in which case, what optimizations can be done on the user end?
    As far as sending data to Iray goes, reduce texture size, simplify geometry, and use instances.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    it should render faster if a static scene just the camera moving as the geometry doesn't need to be updatec
    margrave said:
     and use instances.
    Great idea! Forgot that DAZ Studio does instances.
  • RodrijRodrij Posts: 158
    edited May 2021
    If you leave a render window open before doing the animatino rendering, asset loading times are reduced. The downside is it takes a little more VRAM. Also don't have more than one render window open because each open window takes up VRAM. You'll only need one.
    What I do is a spot render in window mode in tool settings for spot render, leave the render window open, then do the animation.
    I'm guessing when you leave the render window open, the assets are still loaded into memory so when you start the animation render the assets are already loaded.
    Post edited by Rodrij on
    I do have plenty of that to spare, thank you for the tip, I'm gonna try that out soon. Cheers!
    Huh! That trick trims off about 2-3 seconds, which across an 800 frame batch render, really adds up! Thank you!
  • Been meaning to ask, what kind of hardware upgrade could I consider to further trim "load in" times, will faster ram help the situation at all? I already use an SSD.
